1 - 3 of 3 Posts
Hi im new hear but have a fair knowledge of d-series engines, however im looking for some gurus advice or info.... basically i race in a formula where you have to use a D14 engine on a weber 32/34 DMTL carb. Most people prefer the D14A4 engine over the D14Z1. These are the 2 engines permitted. Ive done a fair bit of research and they produced 89-90bhp the Z1 has a higher compression ratio so surely would be the preferred engine. Also would putting a D16 skimmed cylinder head make much difference (v-tech not allowed) any changes i can make to gain a bit more power using D series parts or a cam that works well in a d14?
Thanks in advance
93 dx + 92 lx
What kind of rpm are being turned in the class? Can you post a link to or post screenshots of the class build guidelines?
We had a car running carbs years and years ago its a pretty easy setup. One dude here ran seriously quick and his build will entertain and enlighten as im pretty sure he turned some rpm. Perhaps someone recalls the pink pnw based carby guys screen name so dude can find his old posts?
1 - 3 of 3 Posts
