hi, i'm currently do this combo right now.
d13 block with p08 head.
just now i try to check piston to valve clearance.
with timing belt installed it is good when i turn the crank.
there is no sound valve hit the piston.
but if i set the piston to TDC and not installed timing belt valve hit piston (i think it's normal right??)
the problem now is why my timing belt can't be tight.
like the timing belt hv more 2 teeth..
so, which timing belt i must use for this combo???
can anyone help me??
i will post some pic later..
thx..
Probably.
Get 14400-P2A-004 or 14400-P08-004. Both have 103 teeth and should be good.
thx mate...
i already try that timing belt just now..
but it's to tight... :(
tomorrow i will change with 104 teeth.
i think it's suit best..
