1 - 3 of 3 Posts
I may be getting a DOHC ZC EF but I think the trans is going bad will a regular D series trans work? If so what all do I have to change to make it work or is it a bolt in swap?
Thank you! It may not even need a tranny but im thinking it will... It is stiff going in 1-5 and almost impossible to get into reverse if its running. Its almost like the clutch isnt disengaging all the way which is the first thing I am checking if I get it because if all it needs is a clutch cable or clutch ill be set lol.
1 - 3 of 3 Posts
