1 - 20 of 24 Posts
hey guys,
i compiled a lot of information from a very reliable source, I CAN OFFER IT TO YOU GUYS IF YOU ASK ME WHAT YOU NEED, IM NOT GONNA TYPE ALL OF IT. BELOW IS ABOUT 1 PAGE OUT OF PROBABLY 6 ON JUST THE D16Z6. LET ME KNOW WHAT YOU NEED.first engine:
D16Z6
VIN CODE: EH3,EH9,EJ1 (HATCH,4 DOOR, COUPE)
Valve clearance:
INTAKE .007-.009IN (.18-.23MM)
EXHAUST .009-.011IN (.23-.28MM)
OIL COMPACITY:
3.5QTS. INCLUDING FILTER
COMPLETE ENGINE OVERHAUL = 4.2QTS
OIL PRESSURE:
OIL TEMP @ 176 DEGREES FARENHEIT
10 PSI @ IDLE
50 PSI @ 300RPM
OIL PUMP SPECS:
INNER ROTOR TO OUTER ROTOR RADIAL CLEARANCE: .0010-.0060IN (.025-.152MM)
SERVICE LIMIT: .0080IN (.203MM)
HOUSING TO OUTER ROTOR RADIAL CLEARANCE: .0040-.0070IN (.102-.178MM)
HOUSING TO ROTOR AXIAL CLEARANCE: .0010-.0030IN (.025-.076MM)
SERVICE LIMIT: .0060IN (.152MM)
ENGINE SPECS:
DISPLACEMENT: 97CI (1.6L)
BORE: 2.95IN (75MM)
STROKE: 3.54IN (90MM)
COMPRESSION RATION: 9.2:1
HORSEPOWER @ RPM: [email protected]
TORQUE FT/LBS @ RPM: [email protected]
CRANK,MAIN AND CONNECTING ROD BEARING SPECS:
CRANKSHAFT END PLAY: .004-.014IN (.10-,35MM)
SERVICE LIMIT: .018IN (.46MM)
CRANK TOTAL RUNOUT: .001IN (.03MM)
SERVICE LIMIT: .002IN (.05MM)
MAIN AND ROD OUT-OF-ROUND: .0001IN (.0025MM)
SERVICE LIMIT: .0002IN (.0051MM)
MAIN AND ROD JOURNAL TAPER: .0001 (.0025MM)
SERVICE LIMIT: .0002 (.0051MM)
ROD JOURNAL DIAMETER: 1.7707-1.7717IN (44.976-45MM)
MAIN JOURMAL DIAMETER: 2.1664-2.1654IN (54.976-55MM)
CONNETING RODS:
ENDPLAY: .006-.012 (.15-.30MM)
+ A LOT MORE!
THANKS,
-JACK
1993 Cobra
Awesome! Def a red dot....i mean green dot for you! lol Could you pm me specs for the B7 and A6?
1993 Cobra
haha, sorry. I'd like to have the B7 and A6 crank, rod and main bearing specs please.
1993 Cobra
CONNETING RODS:
THANKS,
-JACK
I need this info for the A6 and B7.....This is all I need, nothing more.
d15b7,B8,Z1
ROD JOURNAL DIAMETER: 1.6526-1.6535 (41.976-42mm)
MAIN JOURMAL DIAMETER: 1.7707-1.7717 (44.976-45mm)
CONNETING RODS:
SERVICE LIMIT: .016IN (.40MM)
LARGE END BORE DIAMETER: 1.77IN (45MM)
SMALL END BORE DIAMETER: .746-.747IN (18.96-18.98MM)
PIN TO ROD INTERFERENCE: .0006-.00016IN (.014-.040MM)
ROD BEARING TO JOURNAL OIL CLEARANCE: .0008-.0015
SERVICE LIMIT: .0020
MAIN BEARINGS TO JOURNAL OIL CLEARANCE:
JOURNALS 1&5: .0007-.0014
JOURNALS 2,3&4: .0009-.0017
SERVICE LIMIT FOR ALL JOURNALS: .002
D16A6
CRANK TOTAL RUNOUT: .0006IN
SERVICE LIMIT: .001
SERVICE LIMIT: .0004IN
MAIN JOURNAL TAPER: .0001IN
MAIN JOURMAL DIAMETER: 2.1644-2.1654IN
CONNETING RODS:
OUT OF ROUND: .001IN
TAPER: .001IN
LARGE END BORE DIAMETER: 1.89IN
ROD BEARING TO JOURNAL OIL CLEARANCE: .0008-.0015IN
SERVICE LIMIT: .0020IN
JOURNALS 1&5: .0007-.0014IN
JOURNALS 2&4: .001-.0017IN
JOURNAL 3: .0012-.0019IN
SERVICE LIMIT FOR ALL JOURNALS: .002IN
ROD SIDE PLAY: .006-.012IN
SERVICE LIMIT: .016
just size of pistons and conrods really
d15b2
CONNECTING ROD BIG END DIAMETER: 1.61IN (40.9MM)
SIDE PLAY: .006-.012IN (.15-.30MM)
PISTONS:
CLEARANCE: .0004-.0016 (.010-.040MM)
DIAMETER: 2.9520-2.9524IN (74.981-74.991MM)
the flow rates of oil pumps a6/z6/y8 (1.5 pumps too if they flow less) would be really sick. It was stated that the y8 has a lower flow rate then all the other oil pumps.
Outer diameter of bearing, Main girdle - 2.3228"
Outer diameter of bearing, Rod end - 1.8898"
Does that help?
1 - 20 of 24 Posts
