1 - 20 of 97 Posts
Please post your current D-series project. Stay on topic.
Ready to install:
Project Junkyard Dog
D15b7 Intake Manifold w/ H22a1 TB
OBD0 Prelude injectors
P06 ecu
D16y7 head
D15b7 block
New Projects:
PM4 (JDM ZC SOHC) Intake Manifold w/ Dual Keihins
D15b2 block
D16y7 head
SOHC ZC distributor
MSD wires
Holley fuel pump
HP Racing Header
y7 Exospeed cam (next on the list)
W
well right now i have a d15b2 with the mpfi swap
in a couple of weeks it'll be a
d16y7 bottom end
d16y8 vtec head (msd rpm switch to activate vtec)
si tranny
full ram intake
2.5 exhaust from downpipe
y8 header
D
1987 Civic Wagon RT4wd
DOHC browntop ZC...oem carb'd
Weber 32/36 DGEV...custom adaptor plate(sort of a venturi effect)
Phenolic intake manifold gasket...keeps intake charge insulated from the heat of the head/block
Bomz adjustable cam gears
D16a6 Kamikazee header
Exedy clutch, slightly lightened flywheel...heh heh -3lbs.
Koni Reds
Miata rims (powdercoated black)
Big Pimpin Grant steering wheel and Ford cassette deck
And still working on:
exhaust...have all the parts, just need to weld it all together
WRX hood scoop...have it, but debating on color matching the paint or black like the trim
AC lines...need to be custom bent
interior...looking for some decent tan seats
Some chassis bracing...maybe a full cage
all said and done...slightly better power to weight then a 2000 Civic Si and the 4wd still works.
J
Here is my project even though it isn't that nice.
-a6 block with pm6 pistons. New piston rings and bearings(bearings and rings coming shortly)
-y8 head with 93 non vtec valve cover
-z6 intake manifold with teg 58mm tb
-Neuspeed header(still on dippincrx's car cause we haven't taken it off yet)
-Thermal cat back
-aem intake
-skunk2 short shifter and knob
-tenzo front and rear upper strut bars
* needed soon*
-Vafc or convert to obd1
-new struts and springs because my suspension is shot
-MORE POWER to go b16 hunting!
No more Honda's :-(
Civic CX
i have almost all of my parts now to build my motor. it's gonna be.
y8 block
z6 head
y8 cam
z6 intake manifold (for now OBX later)
aem cam gear
pm7 pistons and rods
chrome rings
arp rod bolts
arp head studs (don't have yet)
either honda or acl rod and main bearings (don't have yet)
y8 head gasket (don't have new one yet)
haven't decided on clutch yet
00 y8 trans
4-1 header (can't find a good cheap one)<---- just bought one
oh yeah and p08 ecu with a p30 program on it and afc for any further tuning.
not to bad of a setup i hope.
My old project is in my signature this is my new project:
93 D16Z6 308k miles
Plans:
Bored out to 1.8? or new sleeves
custom exospeed highcomp. pistons
Crower or Exospeed race cam
Crower valvetrain
oversize valves
Indivudal T/B's
Adj. CAmgear, Bigger Injectors...havent decided which yet
P&P, Hondadata engine manag., hondata intake gasket
MSD Ignition, 6 Puck Clutch and 7.8lb Flwywheel, Phantomgrip LSD,
Eagle Rods....Bisimoto header. i havent finished all the planning quite yet... but i will update changes...or if i forgot something... :honda:
project in progress
d15b2 block
d16a1 pistons & rings
d15b2 head
exospeed race a6 cam ( in process)
port and polish head
y8 head gasket
aem cam gear
zc trottle body
8mm plug wires
hp header
act disk w/ daikin perssure plate
si tranny
mpfi swap
pm6 w/ superchip
B
91 crx si
coverted to obd1 running p28 custom chip.
jdm d15b
milled head
crower stage 2 cam
zex valve springs, retainers
si tranny
act 8lb flywheel,
centerforce dual friction clutch
y8 intake manifold, b18b throttle body
pretty simple for the most part.
Prolly forgetting some things but oh well.
M
Project for next year, or hopefully before December ends (whichever comes first, and funds available):
new injectors
high compression pistons
connecting rods
valve springs
valves
Basically I think that's it for my engine. Other things might be added, like JDM interior parts (switches mainly, plus the JDM foglights). Lastly, cf hood and a new ECU.
9
d16z6
JG Proseries head
with 85vt80cam
JG springs and retainers
4-1 header
Aem cam gear/AEM CIA
on order.
TEIN's basic coilovers
2.5 exhaust
J
98 LX Sedan
Currently:
Y8 Head
Y7 Block
Injen CAI
Apex'i VAFC
H&R Springs
Tockico Blue Shocks
Tenzo-R Front and Rear Upper strut bars
Tenzo-R Rear Lower Tie Bar
Cusco Front Lower Tie Bar (U-Bar)
Sonar Dual Angel-Eye Projectors
Future Plans:
Skunk2 Adj. Cam Gear
Crower Stage 1 VTEC Cam
4-1 Header
GReddy EVO cat-back exhaust
*Maybe GSR or LS Swap then Boost.... maaaaaybe
M
1997 4-door Civic LX automatic (I know, I know, but its so sleeper)
D16Y7
Now:
12:1 compression Endyn RWs
Eagle H-beams
Y8 intake manifold ported by me
el cheapo CAI
ported honda 4-2-1 header from 2000 EX
2.25" mandrel bent exhaust/magnaflow universal muffler
test pipe & O2 sim
Soon:
ported head by me
stainless undercut valves
chipped ecu
1991 CRX Si
D16A6/Z6
Now: 100% stock
Waiting to be assembled:
Z6 head ported/chambers by me
Crower Stage 2 Turbo cam
Isky valve springs
Eagle H-beams
Endyn FI RWs
posted block
.48/.60 T3 with ceramic impeller
giant fmic
Soon:
rewelded e-bay ssautochrome turbo header
hondata
homemade water injection
homemade fiberglass intake manifold
gutted interior/ fiberglass sunroof plug and dash
D
project in progress (rebuilding an '88 DX sedan)
d15b2 block
d16z6 head and intake
p28 ecu
8mm plug wires
cold air intake
mpfi conversion
obd1 conversion
more to come...
I used to be Admin.....
Soon to be:
y8 block
a6 pistons y8 rods
arp rod bolts
PnP z6 head
Crower valvesprings
Skunk2 Ti retainers
milled .020
Lookin more and more like an Exospeed cam :wink:
VAFC
Its all gettin stuffed into my fat-hoe-of-a-coupe 97 EX.
1993 eg8 - harvard blue pearl
JDM D15B
Lsd S20 tranny
y8 intake manifold (not yet installed)
y8 head gasket
b16 tb (also not yet installed...need to match port im)
short ram intake
2.25" cat-back exhaust
"high-flow" (punched) cat
short shifter
in the near future:
port out the y8 im
match it to the b16 60mm tb
port the head myself (practice on old d15b7 first lol)
dc 4-2-1 header...stock heatsheild welded on
plain honda valve cover (no vtec label)
aem v2 cai
new cam...springs...etc. etc....dunno which yet
pm7 pistons (if they'll fit....hearing differing stories)
shot-peened connecting rods
hmmm nice topic ...
current setup :
97 civic dx coupe
97 y8 p2p ecu
96 y8 t/b
96 y8 IM
y7 block
99 ex c.a.i
2.5 inch piping from cat.
apex n1 muffler
gutted interior ( no trunk/ backseats / side panels/
/ spare tire .. etc. )
si tail lights ( just to be cool )
stock honda steelies < -- AHHH killin me on weight
soon to be instaLLed :
racing hi flow cat and resonator
straight pipe ( hehehe not gonna be cali legal ANYMORE )
y7 exospeed head
dyno time
apex vafc gen. 1
tein JDM coilovers
14 inch Watanabi rims
nitto rubber
sparco torrinos
9
D15b7
Y8 intake manifold (ported and polished)
B18B TB
A6 cam
AEM intake and cam gear
Tsudo exhaust and header
Bout it for now looking to do a Mini-me in the near future.
D
HHmmmm...
D15B (JDM)
4-2-1 Stock JDM exh. manifold
ZC Intake man.
H22 TB
5zigem muffler
2.25 tubing
MSD-sci Ign.
Msd coil, with wires
WeaponR intake
AEM cam gear
( still seaching for a new cam to fit the D15B??Any suggestions??)
uuuhhh..... thats all for now!!
1 - 20 of 97 Posts
