1 - 20 of 35 Posts
honda si ef
i need some opinions on an intake manifold i have a sohc zc and am looking to drag race with this application and need one with the best low to mid range power also the sohc zc is pretty much a d16a6 non v-tec 88 91 si engine :confused:
blox has a good mani out now and its cheap
i got a stock z6 mani if u want it
96dx saloon
if you were on a budget, you can get a z6 manifold and get it ported. and why do you want low to midrange power if you are drag racing. wouldnt you want all the power up top.
ryan
ryan
how does your edlebrok intake manifold perform?
96dx saloon
havent had any tuning since i put the edelbrock on but the butt dyno says it helped. when you look at the edelbrock sitting next to the stock z6 manifold, the runners on the edelbrock look way better. they do not have the 90degree bend in them. it looks like a much better manifold as far as flow goes.
honda si ef
Discussion Starter · #17 ·
sorry i was thinking of something else but you guys recomend a mani i have the head ported polished and milled down compression has been raised to 12 to 1 and i have a more agressive cam i just want to know what mani is best for drag racing
1 - 20 of 35 Posts
