1 - 16 of 16 Posts
I am wondering if cranks can be swapped from one motor to a different motor, i.e. can I use a D15B VTEC crank in a Y8 block? I know that this would probably destroke the motor from a 1.6 to a 1.5, but with a larger piston it could end up being about equal.
TIA
Doesn't the D15B VTEC share the same journal size as the Z6 now that I think of it? That's how you can use Vitara's + Z6 rods for boost right? If that's the case it should work shouldn't it?
EDIT: Opps, mains are smaller, rod journals are the same as d16/17's.
Lifetime Awesome Member
'89 CRX HF
rod journals and main journals are a different story
the d15b has 1.6 rod journals, but still has 1.5 main journals
so no, it wont work
88 ED6
so no, it wont work
:werd:
Discussion Starter · #10 ·
so no, it wont work
Ah ha - thanks for clarifying that. I was trying to work with stuff I had since I am about to buy a sleeved Y8 that's just a bare block. I guess I will try to find a cheap Z6 or Y8 if I can't find a crank. Thanks for the help fella's.
so no, it wont work
I can make it work, won't be cheap, but it is planned for next winter.
1 - 16 of 16 Posts
