1 - 12 of 12 Posts
96 Civic EX
i found a listing for a clutch for d series but im not sure if all d series have the same clutch pressure plate and throwout bearing. so do they?
^^ I think mine did too, cause I don't see it???
I asked the same question...
Ok then any 90-05 Civic SOHC clutch with Disc outside diameter of 8 3/8", spline inside diameter of 7/8", spline count of 20 will work. You have a hydro clutch so you need a hydro release bearing 92-05 have the same one..
im using d17 pressure plate on my 95 coupe z6 =) most work just search and you will see ho easy it is to know.
I just used a 91 crx pp on a D16z6 flywheel
enjoying the 13% increase in clamping force?? i know my old 200whp build enjoyed it. :D
Any research behind this %13 increase?
1 - 12 of 12 Posts
