yea im n/a right now but by next or the following month i should be boosting. so i just wanted to kno if the d/p that come w/ those kits will bolt up to the test pipe.the test pipe should have the exact same flanges as your stock cat. What is this down pipe you speak of? According to you sig your car is n/a...
it will only work if you have the kit... if you have a different mani (and possibly a different snail) then the downpipe prolly won't fit... but the kit is designed to bolt right up to the stock exhaust...yea im n/a right now but by next or the following month i should be boosting. so i just wanted to kno if the d/p that come w/ those kits will bolt up to the test pipe.
