1 - 3 of 3 Posts
96 EX Coupe
So I recently just built a d16 and I’ve had problem after problem from exhaust to fuel delivery to knocking. So finally got the car up and running took it for a couple runs. Now mind you we just got it running the day before and turned on 2-step and bumped the limiter to 8k rpm. Did a pull and after words it was knocking. I have videos to show everything I’m just looking to see if there’s any commons things that break with vitaras that would cause it to knock.
Sloppy Jalopy
d16.....?
knocking and stays knocking?
any way its probably a y8 and you ran too much ignition advance ..
or ran it lean when you had your fuel issue and hurt something then...
is it piston or bearing knock sound?
some basic info of your stuff might help others help you...
1 - 3 of 3 Posts
