1 - 7 of 7 Posts
What would be a more reliable way, cx mani or redrill the dsm?
I could keep ac if i used these with a dsm t25 right?
Thanks
Bobby
Idk if u can use a dsm mani on a civic motor. F/H motor yeah it'll work. If u can get a custom adaptor for the cx mani then u should be able to keep your ac.
C
cx manifold will not allow you yto use your a/c in most cases. id go with a log manifold or some sort or a proper cast manifold such as a revhard or inline pro or something.
dsm maniolfds work for f/h series not b or d series
ccfab what do your manifolds run at for an internal wastegate.
W
Does anyone know where i can get an adapter plate made to put a 14b on a cx manifold? I could make one myself, but just havent had time here lately. New or used dosent matter, as long as it will work.
1 - 7 of 7 Posts
