1 - 20 of 40 Posts
yes yes i've searched, and than i searched again and i still can't seem to find it. I'm not even sure it was in a JRSC thread but someone had mentioned a guy who still makes one off JRSC pulleys for i think 150-160 a piece. A friend of mine was supposed to turn one for me but he's flaked out on me so i'd rather just pay this guy to make me one. I knew i should have wrote down the info when i read it but i didn't so the search is on, if anyone has any info i'd greatly appreciate it.
thanks guys, much appreciated info, i'm only at 7lbs now, i'm not going any higher than 10 but even at that i'll have a water/ meth setup.
any smaller than 3.4" with a z6 crank pulley is border lining the safe operating RPM's for the M45. you can buy the 3.4" pulley directly from moss motors for around $135
You wouldn't happen to know the part number for that would you, that's the pulley i need. I have a parts list but none of the upgraded options are on it and there not listed on the Moss Motors websites, i buy all my belts and gaskets from them
Meat Popsicle
91 CRX Si
They don't list part numbers for individual pulleys as far as I know. The CRX kit cam with this:
051-331 S/C GEN3 M45CCW 3.4-4R 1
The Z6 kit came with this:
051-414 S/C GEN3 M45CCW 3.8-4R 1
In other words, the blower/pulley combination was sold together as a single part #.
Not to say single pulleys are not available, but they're not available by searching for a part number
Meat Popsicle
91 CRX Si
051-400 enter that in the part # box Here and a 1 under qty. thats assuming you have the d16z6 kit.
:uh: shows what I know lol
Having a custom one made is still cheaper tho!
HONDA
just out of intrest what is the diameter of the z6 crank pulley? i know the a6 is 5.75" the one im using with a 3.1" snout pulley. at 7800 rpm. is around 14400 odd rpm on the rotors.
If you have not ever seen this than you should of... Index of /media/CALCS
On my A6 I ran a Z6 pulley for a while and gained 1psi its not that much bigger than a A6 the gains I saw was when I went to a Y8 pulley.
HONDA
forgot about that site. bookmarked. yeah thanks. very helpful.
seeing as i was working a a 6" pulley diameter and was getting 14400 odd at 7500 im more then safe. any way.
moving on. this thread is answered above.
I measured all 3 of them carefully a while back, and there was a significant enough difference in size for me to consider all 3 for boost altering purposes. A difference of 30 thou is NOT significant in my opinion.
That FTL Racing spreadsheet has them at A6 - 6", Z6 - 6.25", Y8 - 6.5", and that seems more like the differences I was getting when I measured.
EJ6
I measured my Y series pulley and it's around 6.4". IIRC, Jackson shipped those kits with a 6.2" pulley to keep the boost at the same level as the earlier kits. Jackson Racing made a larger 6.75" crank pulley for more boost.
I run the 6.75 crank pulley and a 3.8" blower pulley and I get roughly 10 psi boost.
Meat Popsicle
91 CRX Si
:uh: I don't understand...
You ask who makes pulleys, you say you're ready to pay $150-$160..
I spoon feed you and direct you to a $95 custom pulley...
You rep the guy who linked you to a $140 pulley from Moss Motors...
Have fun overpaying!
1 - 20 of 40 Posts
