1 - 20 of 21 Posts
97 civic hatch
this probably has been covered a couple of times and i apologize about the lack of pictures but read close and its pretty easy...
1. get your fabric...the thicker the better OR find a fabric with a "backing" on it, this makes it easier to glue without the glue coming thru the material (looks like shit)
2. get yourself a can of spray adhesive i used 3M's 77 spray adhesive
3. take your door panels off
4. locate what is holding your door inserts on (iin my case the 96-00 hatches have about 20 some million freaking plastic rivets which were melted on)
5. remove these above (whatever they may be) i had to use a simple pocket knife, a dremel tool probably would work better
6. remove door insert material (should peel right off)
7. sand the bare insert with fine grit sand paper, i used 220
8. clean surface and let dry
9. spray your cleaned and dry door insert with spray adhesive until fully covered (careful not to over saturate insert) let glue get tacky
10. cut fabric about an inch and half bigger than door insert
11. apply material and stretch to remove air and folds
12. trim material and tuck inside door insert
13. put door insert back on door panel ( i had to use screws and washers to get it to hold)
14. stand back and admire your work!!!
15. repeat steps for other door!
i hope this helped those of you who asked for a DIY on how i did my inserts
here is the link to my showcase forum of my work
http://www.d-series.org/forums/showcase/141410-custom-door-inserts-take-look.html#post2211660
sorry about the lack of picture cuz i wasnt planning on doing an DIY but people asked and i delivered!
ENJOY
post any pictures or extra steps of your work!
91 Civic 4dr
Repped! :bigok:
Awesome DIY.
Edit: Maybe I can use this for a headliner too
I swear if i go to wrap another crx headliner and it sags because of following you and another guys advice & success you will get mailed a nice hot steaming pile of buffalo SHIT!
97 civic hatch
advance auto parts... go get the headliner spray when you do your headliner and as far as your bandana inserts id see if you can get another thicker material to tack it to just to make it tight then try it...shit even an old shirt would probably do
you mean like put a white tee down and just like staple the bandana to it?
'97 hatch
You're talking about the mid-strength 3M stuff? (vs. the heavy duty version for the actual backing piece, or carpet/whatever)
I've been wondering what won't soak through but still tack fabric effectively.
Nice DIY write-up, btw. Info should come in handy for me soon.
ya the glue is the biggest part and the tack up time of it.....i have never had a problem with super 77....or 90
i prefer the 90 but you have to make sure it sprays out in that stringy like consistancy....and stay away from the ones that say "headliner glue" they are basically like water...
also make sure when appling the fabric start from the middle and push out wards...helps to have an extra set of hands....and make sure to use a roller or side of your hand to push down all aeras of the fabric to ensure a proper bond.
97 civic hatch
yeah like glue or staple or even stitch the bandana to the the t-shirt or whatever fabric before wrapping anything, the t-shirt is only acting as a backing to keep the glue from soaking thru, trust me it looks like piss!
and as far as the 3m 77 spray glue it holds pretty damn good my buddy put his arm rest on with it a while back and still doesnt have any bubbles or seperation even after having his arm pressed on it all day
good DIY
95 Solvic, 93 dS si
as far as adhesives i would stay away from 33 or 77, i used them almost 2 years ago to completely rewrap my interior
I live in the NW, so we have fairly mild winters and summers, however even after prepping to the specs listed the adhesive has already started to let go, by the summer I am going to have to completely rewrap my interior again. Ill be using 90 this time. Also headliner adhesive doesnt work for shit, dont bother trying it.
97 civic hatch
well yours is vinyl that shit you have to heat and stretch my buddy had to get his done at an upolstry shop cuz he couldnt get it to stick
95 Solvic, 93 dS si
actually had to do very little heating, and almost no stretching, its marine vinyl, nylon mesh backing, so it doesnt stretch for shit anyways haha.
98 Civic DX Coupe
i used super 77 on my door inserts and headliner, it's going on 3 years and holding strong. I wraped it in black tweed
97 civic hatch
Discussion Starter #19
my faith is in 3M 77 spray for the door panels but the headliner i got some "heavy duty headliner spray" and yes the crap works
AUSDM EG8 Sedan
this looks fantastic - i will be using the same type of material to re-trim the center of my bucket seats and my door trims =)
1 - 20 of 21 Posts
