1 - 17 of 17 Posts
my current set up now:
d15b7 manual
*garrett t28 comp 60. and turbine 64.
*custom cast manifold
*turbosmart ultragate 38 wastagate with screamer pipe
*turbosmart manual boost controller
*complete intercooler kit
*3" down pipe from turbo with 2.25 exhaust
*obx 10.3mm spark leads
*short metal pipe with a air filter
*braided oil feed/oil drain hoses
*autometer boost gauge
*hondata s300 with p28 ecu
*apexi turbo timer
new stuff recently:
*exhaust wrap
*autometer water, oil pressure
*distributor
*hks sqv3
*catchcan vented
i got a d16y1 engine which im building along the side
now the shopping list to come for the d16y1:
head:
*edelbrock intake manifold
*bisi 2.4 cams + adjustable cam gears
*valve springs+retainers from bisimoto, not sure what i should do with the valves it self. mite leave it as is.
*port/polish
*omni 70mm throttle body
block:
*forged i be lookin at getting these: CP Pistons Eagle Rods Honda Civic D16 D16A6 D16Z6 D16Y8 | eBay
in 75.50mm
*darton sleeves in 75.50mm if i can find it.
*oem bearings
fuel:
*aem fuel rail
*rc 750cc injectors
*aem fuel regulator
*obx fuel press gauge
*hondata 4bar map sensor
transmission:
*fidanza light weight flywheel
*xtd stage 4 clutch
*mfactory lsd
others:
*greddy electronic boost controller
*aem wideband or inovate
*autometer , exhaust , , oil temp gauges
*aem water/meth injection
* new 3" catback with 100cpsi, cat 2 resonators, hi flow muffler
*maybe new radiator??
i think i listed everything i want. still thinking of wacking a jackson supercharger
peace.
stuffs/to do list coming up shortly:
aem wideband
competition clutch stage 4 and lightweight flywheel
put in my d16y1 gearbox
adjust ignition timing
put stock mufler mean time until i get a varex 3".
braided hose entire engine bits.
heres the pics:
Kinda over built for 300 do some more research and you can get away far cheaper and be just as reliable
Agreed i guess u have a flexible hp range as far as ur engine being stout and capable :3dtard:
I would have ditched the following items:
*aem fuel rail
*aem fuel regulator
And rather put the money into a better suited turbo for 300whp++. I personally would rather have a small turbo and xxxwhp less for the responsiveness, but if you want a high hp build, a t28 will be a bottleneck.
z6= 2 oil holes in the rod journals
y8= 1 oil hole in rod journal
Hence why y8 tend to burn up bearings
*aem fuel rail
*aem fuel regulator
Or just keep those (except for the fuel rail, mainly for looks) and build it for 450whp+
That and this -
Y8 pump displacement is 33.4liters/min @ 6800rpm
Z6 pump displacement is 45liters/min @ 6300rpm
Could be a factor...
EFR 6258 should be good for ~380whp and should easily spool earlier than a GT2871R.... Not to mention it's got a (great) internal wastegate and a great BOV built in (supposedly keeps turbo speeds up during shifting).. Now this is on a 1.8l Miata engine.
Pink line is a GT2871R @ 17psi, on E85. Also on a better manifold than the EFR-6258 (Blue lines).
1.8L DIY Turbo Set-up with BorgWarner EFR-6258 - Miata Turbo Forum - Home to the Turbo Miata
thanks guys for replys.
also forgot to add the fuel pump, hd driveshaft to the list.
was thinking all week if i should upgrade to a better turbo, and mite as well.
1 - 17 of 17 Posts
