481 - 500 of 535 Posts
I jus bought a all stock 98 dx sedan came with a d16y7. Im not sure how I wanna go about my build..All motor vs turbo i do have a whp goal of atleast 170 any suggestions???????? pls help
89 acura integra ls
a6 block with pm7 rod and pistons (balanced)
arp head studs
OEM headgasket
std deck
head: resurfaced. maybe .005", full race ported also gasket matched,3 angle valve job
msd cap,rotor, sci (no limiter pill)blaster ss coil
vms 10.2 mm wires
optima battery
and some more ...
supertech: std high flow nitrate coated valves (backcut), valvesprings and titanium retainers, keepers, stem seals.
exospeed kobe special cam(as soon as it returns)
skunk2: alpha series 66mm tb, battery tie down in the trunk, pro series cam gear, oil cap
bbk: 3" short ram(full in the summer), 255 lph fuel pump.
blue samco silicone hose kit.
mishimoto rad and high pressure cap
cheap high flow fuel rail
aem: fuel pressure regulator, wide band o2 uego
gates racing timing belt and alt belt
bisi style header( very nice header just not the real bisi)
qtp 3" electric cutout
full 2.5" exhaust into a super 10 series flowmaster with pilot motorsports resonated tip
energy suspension polyurathane inserts for mounts and everywhere else
89 acura integra ls
arp head studs
OEM headgasket
std deck
vms 10.2 mm wires
optima battery
and some more ...
I left some vitals out
y8 m/t honed out and port matched
s300 hondata
1" tb spaced port matched
i want 200 whp but mor relaistic 180whp im thinkin
Your suggesting a turbo...about how many psi would i have to set it to and would i have to reinforce the internals or jus keep them stock??
93 del sol si
Im planning an all motor build for my dd *looking for around 250-300whp* here goes:
On a pretty tight budget as of now but will look up in the future. I'm trying to use parts and tooling that are readily available to me (ie machine shop, fab shop and my garage lol)
Parts: Block, crank, connecting rods will all be d16y7 Head will be d16y8 (milled 0.019" along with a p/p) 0.025 head gasket Pm3 pistons out of d15b7 (will be shaving 0.060" off) Of course arp bolts I should be around 11.1-1 c/r and piston to deck should be about 0.020" allowing a little room for stretch.
As for which cam, tune I will be using im not sure yet
would like to hear some suggestions first
Give me your 2 cents all opinions are welcome
I would go with forged internals with a nitrous kit and eb intake and a 1.7 crank to make it a stroker
My JDM d15b (d15z7) Build
So Far:
OBDII JDM D15B Block Bored
Stock Rods & Crank
All New Bearings / Polished Crank
PMS Pistons 1st Size over with OEM Civic GX Rings (from my local dealer)
Y8 Intake Manifold Ported w/ B20 TB
DSM 275cc Injectors
Reworked Original Oil Pump
Waiting to pickup a y8 head which will get ported and polished thermal coated and microslick on the valves.
Still trying to settle on a cam.
d16z6 pm3 pistons 11.75:1
d16z6 block stock
z6 head stock
pm3 d15b7 pistons 11.75:1 compression
cosmetic headgasket
apr headstuds
hondata s300 with light tune
d15b8 fuel econ trans long ass gears junk
in need of or soon to come
d16si or ex trans
wideband o2 sensor
tune
a year or so a turbo kit then it should be alil fun lol
EJ6
I'm planing to build up an D16 Economy Frankenstein. I try to use as much Honda parts as possible :
D16Y7 block
D15Z6/EK3 EUDM head (same as Y8 except the camshaft etc.) ported
D16Y8 intake manifold ported
SKUNK2 cam gear
ITR Airbox (not bought yet, trying to find a cheaper and better solution)
Compression: 10,25:1 (shall i go further ? cause the car is for daily use)
D16Z6 exhaust manifold (i should probably buy s.th. else, mine is starting to crack)
2'' middle silencer
Twin loop muffler
tranny: USDM D15Z1
wheels: 6.5x15 ET38 195/50/15
Plan is to achieve a mileage that is above 40 mpg.
I wanted to keep the power steering and A/C.
I will probably run this on a chipped P28 with a Boomslang converter.
Any suggestions or advice ?
My Daily Build:
D16y7 head and block
Oem Head gasket
STD pm7 pistons
ARP head studs
Stock d16y7 rods
Stock Crank
Y7 transmission with 4.7 gear x final drive/ soon obx lsd
Delta 272 cam
Bisimoto valvesprings, stock retainers and keepers
Kamikaze Header w/ apexi world sport exhaust
z6 intake manifold port matched for s2000 tb
3" piping to ct engineering icebox
Ngk wires w/ iridium plugs
Prelude injectors
91 octane fuel
Going to be tuned on hondata s100
Looking to get 150ish hp when finally tuned
My Daily Build:
Oem Head gasket
STD pm7 pistons
ARP head studs
Stock d16y7 rods
Stock Crank
Delta 272 cam
Prelude injectors
91 octane fuel
All that into it and only 150 hp?! come on man, go turbo if you spending money for that^ and go with s300 not s100. You wont regret it
Yeah it looks like it would be a lot but its actually cheaper than a turbo build. I'm also putting it into a 1982 civic hatch so there is not a lot of room for anything in that engine bay. The car weighs roughly around 1900 lbs so a 150hp and geared out d16 will be stout. I also bought a cable CRX SI tranny so I wouldn't have to convert hydro to cable. I love the power of a turbo motor but I am building this car for a daily/track use so NA is more ideal. I will probably go with s300 since its not that much more.
92 EG, 88 ST165 WRC
Drove it home tonight!!
For my 92 hatch which was a stock B7 car w/197,700 miles on it; the plan was to build this Y8 for boost then swap it at 200,000 miles. The head gasket had other plans, so it's N/A for now.
rebuilt Y8 from 2000 coupe
Wiseco 75.5mm pistons
Honda HG and oil pump
Eagle stock length H-beams
ARP head studs
stock crank; may stick a Z6 in there
Schneider re-ground cam, now 260* duration
decked head .010" but I'm not 100% sure; have to check papers
RActive header, welded the studs so they stop falling out... it came with the car
stock IM, it's for an auto trans but I made the B7's IACV fit/work
P28, re-pinned for manual trans
OBD2-1 dizzy wiring and VTEC harness from 2jzdreamin (good shit!)
B0000 trans that grinds into 4th a little... may stick the A0000 back in
Turbo bits:
GT2860RS
Evo FMIC
RC 550 squirters
aluminum radiator; looks like a knock-off... was just $50 so why not
14" slim fan, may be 12" I forget
Exedy stage 1 clutch disc; also came with the car
No specific power goals; I wanted to build my own engine for once, so here it is.
in the works
D16Z6 block and head
p29 pistons
shot pinned oe rods
self done port, polish, and gasket match
crower stage 2 cams
OBX ITB's
PLM drag header
2.25 custom exhaust with hooker muffler
clutchmaster stage 3 clutch and chromoly 8lb flywheel
msd ignition with a 6al-2 box
undecided on suspension
civic sedan d15b7
eg sedan
D16z6 head:
3 angle
mild port
Black nitride dome valves
Crower springs and retainers
D16z6 Block:
bored .50
P29 high compression
AM rods
exedy pro series clutch
18 lb flywheel
4-2-1 header
stock exhaust for now (yonaka exhaust)
(Saving for 370+ injectors)
Boshe 255 fuel pump
Chipped p28 from hamotorsports.com
Hondata s200 iI plan to have it dyno tuned
Im not pozsitive on safe compression numbers i was thinking around 11:5 or 12:2.1 at most.
I will also be running a jrsc with this set up. Any suggestions or comments?
Honda Civic
First Post
Right now I'm in my second year at college getting my associates in automotive tech. I sold my last Honda (94 Civic EX coupe) about a year ago but I still had the original Z6 I swapped out of it with 233k and decided to build it up for advanced engines class. At the moment it's at the machine shop but I pretty much have everything thats going into it besides TB and injector setup. If you see anything I could improve on let me know.
Head:
Comp 59300 cam
Supertech springs and titanium retainers
AEM cam gear
Nitride valves (no name)
OEM head gasket
3 angle valve job
Block:
Bored to 76mm
Wiseco 11 to 1 pistons
Stock rods reconditioned with ARP bolts
OEM oil pump, timing belt, tensioner, water pump ect.
I'm looking for about 150whp, does anybody think I can do it with the right tune? Thanks
block
-ZC sohc non v block bored .5mm over
-Pm7 .5mm over pistons
-acl race bearings
Head
-d16z6 head
-supertech valves .5 mm over
-comp zex valve springs
-stock z6 retaines
-skunk2 cam gear
Misc
-60mm throttle body on z6 manifold
-j2 one peice header
-gates timing belt
-blox fp
-oem....everything else haha
-rc 310 saturated injectors
-full b16 sir2 exhaust from the header back
-will be tuned on neptune
09 dodge ram 4x4
I'm new to this so if y'all want to give me crap you can. I planing on doing a jdm d16a head which is d16z6 vtec head. I placing it on a d15 block. The cars original motor is a d16y8 vtec. I have a few questions if anyone would be willing to help me. Th y8 head is wore out so I'm not going to reuse it on the d15 block. I'm planning on using the y8 intake. Is this a good idea? Can I use the y8 coil and plug and plug wires? Honestly this is my first time doing this so I could definently use the advice. This is what they call a mini me swap is it not? From what I understand the jdm d16a is rare and produces more hp, is this true?
My racecar:
d16a6 block
d16a6 head
d16a6 pistons (first overbore)
d16a6 rods
stock compression
stock intake manifold
AEM intake
cracked bisi header (do they come any other way)
custom 2" shorty exhaust, burns stainless muffler
