1 - 20 of 222 Posts
Lifetime Awesome Member
POST YOUR PROJECTS!!
figured that this is going well in the n/a section, why not have a FI one?
sohc no-tec zc block
Tuner Toys I-beams
Vitara 75.5mm pistons
z6 head, DIY portjob
z6 IM, portmatched to head and TB
GSR 60mm TB
Cometic HG
ARP headstuds
ACL bearings
Turbo kit:
homemade tubular "mini-ram" style mani
t3 .48/.60
3" DP
Racegate 40mm external WG
open dumptube
obd1 conversion, chipped p06 running Crome Pro
2.5bar Motorolla map sensor
DSM 450s
2.5" charge pipes
JRC or equivilant 8" fmic
SSQV bov
BLOX gauges
full 3" exhaust, 18" resonator, no cat
possibly going to run methanol injection. still doing research on if before i decide for sure.
heres my project:
y8 block built by RSMACHINES
sleeved, 75.5mm bore
srp pistons
tuner toyz rods
ported and polished a6 head by dh-racing
supertech stainless valves, springs and retainers
sr909 cam
unorthodox cam gear
edelbrock intake manifold
full msd ignition, ngk plugs
act 12lb flywheel
centerforce stg1 clutch (i know i need a better one)
91 si tranny-4.437 fd
turbo kit:
ramhorn mani, 3" downpipe, and dumtube from ccfab - if i ever get it!
tial wastegate
garrett t3/t4 57 trim
full 3" kteller exhaust w/3" magnaflow oval and apexi n1 turbo muffler
dsm 450's
2.5 charge pipes
rfl bov
28x9x2 3/8 ebay intercooler
chipped ecu by 5speed4life w/datalog cable and hookup
for wideband - turboedit to tune with
ostrich
i know im missing a ton of stuff.
looks tight man...one thing though...the 450s are on there twice...but hey if you wanna shoot more fuel in your engine thats tight...just let me know how you rig that up...:)...looks like itll be real fun though
oops, fixed :smile:
you can actually rig that up though. Megasquirt allows the use of 8 or more i believe :TU:
dang ryan!!! thats a SICK set up! does the SSQV sound like in that clip i posted?
also how much psi you going to push???;)
not installed yet, still a project :smile:
well the 2.5bar map is good for about 21psi, ill probably run at least 15...
4thGEN said:
heres my project:
srp pistons
tuner toyz rods
sr909 cam
unorthodox cam gear
act 12lb flywheel
turbo kit:
tial wastegate
dsm 450's
2.5 charge pipes
rfl bov
ostrich
looks like fun! i hope you get good results :TU:
have you seen the 15psi sohc vid, the guy runs 310bhp and ran 11.68 at 117mp:TU: so i say go for it! what will you have it rev at?
I'm working on an e85 set-up right now. I'm shooting for a mild 200whp or whatever my fuel set-up limits me to (for now).
D16Y7 longblock
PM6 w/ TurboEdit
Innovate LC-1 Wideband
DSM 450s
Walbro 255-hp
SLS manifold
Custom 2.5 -> 3" downpipe
Custom 3" side-exit exhaust
Custom 2.5" i/c piping
Master Power T3/T4 50 trim, .63 a/r
Tial 38mm
Tial BOV
Vibrant 18" x 6.5" x 3.25" Bar & Plate intercooler
And later:
CP Pistons
Eagle Rods
ARP Head Studs
ryan89crx said:
^^awesome!! what are the hp limits of the 450s when using E85? i know that it takes more fuel to make the same power, so im guessing mid-200s will be close to maxed out
Yep exactly, I'm thinking right around 200whp, but we'll see. Unfortunately my decision to run TurboEdit limits me to 450s, so over the winter once the new bottom end goes in I'll have to switch to something else and in the process convert to OBD1. A new pump and lines will probably also be needed to support more power. Once that's all upgraded the next goal will be 300-350whp on e85.
Discussion Starter #19
nice! you are from MN too, lots of E85 there. my great uncle is a CEO of one of the plants in central MN :TU:
Yeah there's I think 6 stations within 5 miles from my house
I might run a Moates 2Timer with TurboEdit: one map for e85 and one for regular gas. That way I can just flip a switch to change my tune if there's no e85 anywhere. Easy!
:mikej:
1 - 20 of 222 Posts
