1 - 9 of 9 Posts
i have a 91 crx w/ dx tranny. also i have a 94 z6 from an ex civic. this question is about the dx tranny case. is it possible to use the input shaft, countershaft, 5th gear shaft, and ring gear from the z6 trans and stuff it all inside the Dx case. also if i use the dx differential i am guessing i dont have to change the axles. any help would be great. i hate the long gears of the dx trans.
thank you i've taken some transaxle's apart and wasn't sure of the difference in bearing size. would i be better off going after a si cable tranny
Yes. The gearing is basically the same as a 92-95 EX trans except 2nd is ever so slightly longer and 3rd/4th/5th are ever so slightly shorter. Both have a 4.25 FD.
4g vs 5g..........
one gearset is taller than the other, 5g not going into 4g case.
putting a 4g FD into a 5g case, I've done it, about to do it again. Easy way to my a CX/VX tranny useable, drop in a 3.89 FD :)
1 - 9 of 9 Posts
