1 - 4 of 4 Posts
88 CRX
After my engine swap (d16y5 into 88CRX) the temp gauge stopped working. Kind of a dumb question, but where is the sensor for that? or where should it be? It's possible I failed to match it up with the correct plug, because I know the gauge in the cluster is fine.
Thanks
88 CRX
Looking around a bit I found it (sorry, didn't search first, was bein lazy) I'm quite confident that sensor is connected, any way I can test the temp sending unit to make sure it's working? Or should I just assume it's not?
1 - 4 of 4 Posts
