1 - 3 of 3 Posts
I want to swap in the 1.6L ZC Sohc V-tec and S20 gearbox from EG civic into '90 CRX. Is there any major problems fitting this into the CRX ? I know the CRX came with DOHC ZC so the engine blocks are the same but its the gearbox fitment i'm worried about.
I am guessing once mounting brackets are modified correctly the engine and box should fit with enought clearence for pulleys etc. I need some info from others who have done similar type of swaps. Thanks
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
there is a hasport kit you can use to make that tranny work in the rex but IMO not worth it. find a cable d trans for the rex and use the motor and enjoy how simple it was compared to spending 300 on a conversion kit.
Hey man, thanks for your reply. I was hoping that the hydro box would work because they are easier to find than old EF trannies.
I did search and found only 88-91 cable trans will work in EF Civic/CRX. Always need to hear what other members have to say. And I always look here for info, thanks
si-hatch86, you are a true D-series soldier!
1 - 3 of 3 Posts
