1 - 3 of 3 Posts
C
i have a 1989 crx si took out the motor and put in a d16z6.i'm using the a6 distributer i had to open up the holes to make it fit.it worked for a while then the shaft bent in the distributer.i don't won't to put another a6 one on what are my options? another thing i bought a msd rpm activation switch for the v-tec and it's not working. i herd you can hook a shift light to the v-tec is that possible?
1 - 3 of 3 Posts
