1 - 9 of 9 Posts
hi guys i need help I'm having problem with the car .b20vtc turbo .50 trim any way at first i had 240cc injectors and uploaded bin file from download at xenacron it work nice and started up now i upgraded my injectors with evo 560cc injectors so what i did was change injector size and click OK on program. and tried to start the car but no luck on it car wont start pls. need help on this
did you add a resistor pack?
Post your tuning program, some screen shots (remember to reduce screen shots with a paint program so it doesnt take up entire webpage)
Condier the steps you took to change injector size. was it a multiplier? was it a straight <erase 240><insert 560>
Keep in mind injectors are not always rated at 40psi fuel rail pressure. not all cars use an adjustable fuel pressure regulator, and not all cars maintain constant voltage on fuel pump. Some research on your injectors and what vehicle they specifically came from. a kind of car (mitsu evo) is not enough. cars can change on a yearly basis in minor detail
1 - 9 of 9 Posts
