Hey guys, I have a 91 crx with a d15b6. When i start the car when cold it idles at like 2k. Then it will start hunting from 2000rpm down to like 1500rpm. WIll not stop going up and down. I changed all my vacuum lines. Cleaned the Eacv. Can't find the problem. I believe these motors don't have the FITV, right?? When i remove my air intake, I see 1 hole in the throttle body which is sucking air, When i put my finger over it my car idles fine. What can my problem be? Not sure if my throttle plate is closing all the way, will this affect anything? What else can i do?
