1 - 10 of 10 Posts
Seems like the ECU diagram i have is hard to read, and pinouts don't help me perfectly. I have my entire harness sitting outside the car...it's a dirt track race car. Typically in a perfect world I run 3 toggles and a momentary switch...ECU, Fan, Fuel pump, Starter on a momentary. When i wire other stock vehicles i just follow back the wires from the ecu and on the diagram, cut out the splices and miscelaneous things i need, and i end up with a car that can start, charge, and run races with ~ 30 wires from an ecu.
Meat Popsicle
91 CRX Si
Ha the black paint makes it look like it was emgluphed in flames and that’s all that’s left of it.
What year is that chassis?
Discussion Starter · #4 ·
88. If you’re following along with the build I’m lookin for answers as to why the fuel pump primes, but doesn’t stay on once I hit the starter? I can idle it with starter fluid
Discussion Starter · #9 ·
Thanks! I wanted to have somewhere to document the build, just haven’t found a great spot in the forum, or if there is even any desire
1 - 10 of 10 Posts
