1 - 6 of 6 Posts
Hello d-maniacs! I need some advice/help identifying tranny trouble.
Long story short, I had to shift into 5th gear in 1/4 mile just right before finish line. I tried to shift in two runs but kinda missed/couldn't put it in at 8000rpm. After this 2nd attempt when going back to start area, I tried to shift into 5th it went in with crunch. I stopped, pressed clutch again and could only shift with crunch even at idle.
First idea was l broke 5th gear shift fork. I had broken 3rd gear forks many times so I know symptoms.
I took apart my tranny and big was my surprise fork was intact. So I inspected 5th gearset, synchro sleeve and ring and couldn't find problem I was looking for. Synchro sleeve and gear tooth was worn out a little as I had to travel home 750 miles and I had to shift in 5th obviously. But not that much worn that woud cause crunch at idle. My suspect was maybe synchro ring spring had popped out. I assembled everything and hoped for the best...
Crunch at idle was gone, but it crunches when driving no matter how gently I try to shift.
I didn't take photos of sleeve and gearset tooth, but you have to believe me it was not that bad. So what did I brake/bend???
Thanks, Aquafina, for joining thread. I was hoping you or Bense would see it.
I don't think any of picture would help. I had new Syncrotech master carbon kit installed. New sleeves, synchros and bearings. And I didn't have any problem till this mis-shift...
One thing I am thinking now, could s20 aluminum shift fork be bent a little? I have experience of broen 3/4th gear forks, but for 5th it's so much beefier that maybe it could bend instead of crack?
PL3 and S20 5th forks are the same, and pics DO help as Andrew (Bense), Chris (Aquafina) and I might see things the normal person doesn't see.
Worn IGB, aka Interlock Guide Bolt which sets all the shift gates and can effect the shifts. Let alone the shift arm A and the cage.
And of course you Mr. Transzex ?
I will take apart tranny in the winter and inspect/measure it with attention. I would normally take a pictures if can not solve problem on my own, but half of my Civic was out of garage while I took out transmission and I had to put it back the same day.
Interlock bolt is definitely one thing to look at as I have problems with getting it in place every time I assemble my transmission. Sometimes it sees force of "proffessional" work.
I will bring this back as soon as tranny will be out again! Thanks guys!
1 - 6 of 6 Posts
