1 - 4 of 4 Posts
the other day i removed the cruise control cable solenoid from gas pedal to work on the car a little and now my cruise control doesnt work. i was looking at it and noticed broken pieces of some rubber stuff on the floor mat and wondered if that could be the problem. it reminded me of the clutch safety switch grommet when it breaks down. could someone show me where this needs to be replaced if this is the problem? the button on the left side of the dash still lights up but the button on the steering wheel and cluster doesnt. someone point me in the right direction please.
i looked and saw only 1 on the brake pedal, not sure where the 2nd one is. but i did look on my clutch pedal and saw the upper one was there but the lower one must have disintegrated. imma replace this and see if it resolves the problem. and my cars a manual if this helps more
my cruise control works again! i replaced the switch stopper and also the one on my brake pedal bc my brake lights were going crazy
1 - 4 of 4 Posts
