*vitara* umm depends.... I am going with the stage 2 crower turbo cam for my setup.... which consists on vitara pistons....is a crower stage 2 cam good for a vitara setup?
depends on your tune and what turbo your going with and your octane you wanna use... some guys are making 400HP on a stock head and intake with vitara'swell i found out what my setup will consist of
D16z6 block and head
-Vitara pistons
-Eagle H beam Rods
-Crower stage 1 or 2 turbo cam might stick with stage 1 and keep stock valve spings, valves and retainers.
-P&P Head
-Knife Edge and Balanced crank
-Deck the block
-balance the rods and pistons
-Then turbo not sure what though
What you guys think will it make more then 300hp or no?
why on earth would you get a different crank? stock will be fine.
get a gt28r turbo, im sure youll be happy with it.
also what kind of turbo manifold will you be using? is this a race car only or a daily driver?
no offense but it sounds like you know what other people are talkign about but you dont really understand the true purpose of them. but i could be wrong.
