1 - 10 of 10 Posts
my current set up is
z6 head and block
p29 pistons oem rods
stage 2 crower NA cam (63442z)
with BC springs and retainers
RC 440cc injectors
DC 4-2-1 header, test pipe and 2.25" catback exahust
skunk 2 pro series IM, 66mm skunk2 TB and blox 4" intake
Blaster coil, Pro cap and 6AL box.
I am street tuning with hondata s300 on a p29 ecu
my question is about the ignition table and timing.
I remember the specs saying it has 4 deg advanced timing milled in to it.
so I set the timing 12 deg advanced on the dizzy and added it up on the s300 to 16 total advanced.
I want to know if I'm on the right track?
another thing is i keep adding timing and I'm getting good results but i am well over the timing that i set originally
should I reset the timing on my dizzy to match the timing on my ignition table?
I know I am asking a lot but i would really apricate the help!
Was it the cam that stated it has a 4° advance built in?
Then that statement doesn't apply to ignition timing, pull 4 degrees everywhere, reset distributor to 16° btdc, this will put injector timing back where it should be, you can then continue tuning your ignition curves. An adjustable cam gear will benefit you here, if you feel like it's soggy up top retard it 1° at a time, check valve lash, reset ignition timing, do a few test pulls and make some adjustments each time.
Discussion Starter · #5 ·
Thanks for the suggestion it makes sense and I do have a aem adjustable cam gear on my set up currently
16 deg btdc is 16 deg advance?
im wondering if I should just start with the base map d16z6 ignition on the s300 and do what you suggested honestly my ignition table looks pretty wonky after messing with it so much.
Yes btdc is advanced. Was there any block decking or head milling done when the engine was built?
Discussion Starter · #7 ·
No there was not OEM deck and OEM mill, I’m starting to understand now so where could I pull more power from the advancing the timing or the cam and cam gear?
It all works together, retarding your cam timing will move your torque peak further up in the rpms, advancing it will pull it down lower, there will be minor adjustments necessary to fuel and ignition curves to make peak power whenever you move the cam timing. It's important to reset base ignition timing and check valve lash each time you adjust the cam timing, then you make a couple pulls, tweak some things here and there, make a couple more pulls and see how it does.
Discussion Starter · #9 ·
Thanks bro with the info you gave me I re timed it and worked the ignition table a little but and it’s running and idling much better! Thanks
1 - 10 of 10 Posts
