Is the cam timing right? What did you set the valve lash at?
what kind of tuning are you using? If none, there's your problem. When I was using this cam, I had almost 30% of fuel take'n out in idle range just to get it not to stallSo heres the deal. I just installed a crower 2, valves, valve springs, retainers, ported/polished head, and edelbrock IM. I got the idle straight, it idles at around 1500 once warmed up....but after driving around, when i come to a complete stop, the idle drops to about 500, and wants to cut off, so i gotta keep my foot on the gas....and its a real pain in the ass. ive tried messing with the idle screw, but it still wants to drop low after driving around. anybody got ideas of what it is and/or how to fix this? thanks in advance!
Nick
Can i temporarily use the SAFC/VTEC controller from Fields alongside a stock P08 ecu for this?what kind of tuning are you using? If none, there's your problem. When I was using this cam, I had almost 30% of fuel take'n out in idle range just to get it not to stall
It might give you a marginal improvement however without adjusting the timing to compensate for the addition or subtraction of fuel, you won't get the optimal results.Can i temporarily use the SAFC/VTEC controller from Fields alongside a stock P08 ecu for this?
Worry about emissions when you have to. For now though, you have to do it for your set-up to run right. If you won't tune it properly then you shouldn't have even done it.tuning is killing me right now. im on a FPR and FPR Gauge, cause my VAFC i bought dosent function properly. Im looking into hondata, but i cant run it in VA (OBD2...emmissions and all)
X10000000Tune FTW. Spend the money it will be well worth it.
