1 - 2 of 2 Posts
okay guys help me out here abit.
this is my first attempt to tune my car my self.I have more experience on the mechnical side as i did the setup on my car myself. i really want to get my tunning side good as i keep on updating my setup so tht i can save $$$ frm my tuner:yes:.
in the attachment is my first attempt to make a base map for 7psi.
my setup includes
d15b vtec
p08 chipped using crome
t3 dual ball bearing turbo
evo4 intercooler
310 cc injectors.
plz check out the map and point out any mistakes you may arrive at.
this will be really help full.
thanks
got to setup your injectors. set your boost limit to 7. adjust timing for boost. GOnna deff need a wide band sorry this is a must!!!! and at least a chip bunner or a ostrich cause your gonna need to make a few changes to get thinks right.
also is this a minme setup (like a b7 bottom end with a z6 vtec top end? y8?) or the jdm d15 vtec? cause thats gonna play a part in your timing due to compresion.
1 - 2 of 2 Posts
