1 - 11 of 11 Posts
when i open up crome to do a tune ill load a base map eigther one that i downloaded or one that comes with the program and this pops up everytime
THE OPERATION COULD NOT BE COMPLETED BECAUSE THE SCRIPT ENGINE HAS NOT BEEN INITIALIZED TO A VALID LANGUAGE
whats wrong and how can i fix it.
thanks
thanks
are you running vista or windows 7? i know in vista i had this problem as well as with windows 7, you have to run the program as administrator.
crome 1.53 and using windows Vista how do you run it on administrator or u mean administrator mode in vista
are you using crome Pro or crome free?
double check your plugins etc.
make sure checksum routine is removed try that *shrugs*
even better
here...
Crome Start-Up Guide
ok im using crome 1.53 its not pro. I just did run as admin and its still doing it even if i open a base p30 that comes with crome
also run it in comparability mode it seems to be working great for me in all forms of windows try delete and re-install
1 - 11 of 11 Posts
