1 - 17 of 17 Posts
Lifetime Awesome Member
'89 CRX HF
'89 CRX HF
does it work of the clutch switch or the cruise control switch?
neither, AFAIK its set based on how fast you are moving. if its set to disengage at 15mph and you are cruising slower than that and you push the clutch and punch the throttle, it will hit your FTL rpm
someone correct me if im wrong...
I'm not sure either, my brother & I just installed this feature like two days ago, and you can enter the Full throttle launch rpms under the "options or advanced tools section (I don't have it in front of me)". It also has a provision for full throttle shifting which I haven't tried yet, but it should act as a limiter at WOT.
Basically after burning a new chip, I went for a spin. I pull to a stop, push in the clutch and stomp the gas...the FTL rev limiter bounces at the rpm I set it at, and once I let the clutch go, the revs climbed as normal. (with mucho tire smoke..5800rpm & now in boost = one wheel peel wonder)
'89 CRX HF
you can also set the mph that it disengages so that it doesnt automatically scream to redline when the clutch is popped
Where's that located? In the bottom of the options "extra features" box I only have:
Launch Control - rpm.....................Boost Limit - mbar
Full throttle shift - rpm...................................- psi
Shift Light - rpm
Thanks. For those that can't read the thread here's the text instructions.
tools->command(control+k)
type in:
rom.byteAt(0x79EF) = (mph / 0.621371192 ).toFixed(0);
Example:
I want it to disable at 25mph.
rom.byteAt(0x79EF) = (25 / 0.621371192).toFixed(0);
1 - 17 of 17 Posts
