1 - 13 of 13 Posts
I copied stock p28 tables onto a crome gold map and every time I load it my datalog stream will freeze. *It's only when running a crome gold map. *I can copy the same tables to a p30 map and everything works fine, *Im using Ostrich 2.0 and Hulog. *motor is a stock d16z6
Any ideas on whats happening here?
ej8
crome is buggy.
I think you have to open a new gold map.
copy over the p28 map. (adjust the scaling before copying if needed)
Then save the gold map and reopen the gold map.
Then connect for datalogging.
I had this problem long time ago when i use crome and i believe that was the fix.
Discussion Starter · #5 ·
crome is buggy.
I will give that a try. Pretty sure I did that though. It's really annoying
the rpm scaling is different maybe that is messing it up,,,
what does it do if you just run the maps already in place on the gold rom?
I did change the RPM colomn.
easiest solution is to sell your ostrich and hulog and buy neptune
I haven't really had any issues with crome yet. But having the external boxes and wires is getting annoying. They should have a trade in program
ej8
Lol trade in would be great.
But yea neptune is worlds apart from crome.
I ran a lot of differrnt things before and inwould say neptune is the best.
Have ran hondata however. But everyone says its on par with neptune.
Discussion Starter · #7 ·
there seems to be a lot more tutorials and support for Neptune too. I will probably use what I have until I can save up the $400 for Demon and Neptune
91 CRX Si
Did you change your Settings -> Tuner Comm. -> Serial Protocol to Chrome QD3 when using Gold maps (pretty sure thats what it is, been a long time since I messed with my tune)
It's funny you say that. they did have a trade in program years ago. I don't know anyone who buys crome new these days. what tends to happen is old computers and extra license get sold used.
1 - 13 of 13 Posts
