1 - 6 of 6 Posts
Hi everyone I have a zc dohc and is fairly stock besides a good header and 2 1/4" exhaust but I have managed to get my hands on a set of crespo stage 2 camshafts... I race circle track so I was going to throw these cams in for a few nights would it be ok with stock springs and retainers???? Has anybody done this???
RPM--2300-7800 rpm down the straight
thanks for any advice
93 Legend L Coupe.
Don't. Crespo cams are weird and/or will destroy your engine if they aren't ground properly, which happens more often than they would like, I 'm sure.
And stock springs are good for over 8500RPM on nearly any cam you can attempt to run on a mostly reasonable engine build.
Call Geoff at Colt cams.
If you feel you MUST have springs, get in touch with KMS.
You will need to tune, also.
how reliable is the stock retainers?
I can get Rocket Motorsports custom grind for your setup.
Regards!
1 - 6 of 6 Posts
