1 - 7 of 7 Posts
J
i did a auto to manual conversion. when the car is not running you can put the car in gear all day long. when you start the car and try to put the car in gear, you cant get it in gear? the clutch wont disengage enough. with a old worn out clutch it will work. with new aftermarket clutch, it wont disengage? i put on a new slave no fix. i made a longer rod for the slave, no fix. bled the system 3 times no air in lines at all. so i am down to bent clutch fork?
what is wrong?
help
d-series smartass
have you tried adjusting the pedal under the dash? the slave master cylinder on the firewall may also need rebuilt. i've had one go out in my 93. what is year your car?
Ferio inspired
90' Civic sedan
sounds like you have a bent disc. :beer:
J
the car is a 99 ex, with a hx tranny. it also has a act clutch kit and flywheel.
J
is there a chance that i have the wrong throw out bearing?
1 - 7 of 7 Posts
