1 - 20 of 35 Posts
hi i removed the crankshaft pulley bolt to do timing belt etc. when i removed the bolt it had been rethreaded had a look at the crank where the bolt go's into and the crank is also rethreaded is they anyway i can fix this. i have tried a new bolt but its rethreaded that aswell.
could i have a new thread put in it and use a smaller bolt
thanks
racist-bigot-sexist-homophob
Are you saying the bolt/hole is stripped?
95 accord/87 ACCORD
What is wrong with the bolt that you pulled out?
Will it not go back in and torque down to spec?
the bolt that holds the pulley it gos in to the crank. the bolt was stripped so was the crank where the bolt gos into i did get a new bolt but had no luck and it stripped the new bolt aswell.
the bolt i pulled out was stripped so replaced it with a new one and it stripped that aswell. where the bolt go's to hold the pulley into the crank is also stripped the hole of the crank.
Get a tap and see if you can "clean" up the threads in the crank.
i did clean it it but when i put the new bolt in it has lost all the threads on the crank and now is smooth
93 Legend L Coupe.
Get a tap, some tapping fluid, and a tap handle. Attempt to clean up the threads. Or, go through the hassle of pulling the crank, taking it to a machine shop, seeing if they can fix it, paying them to fix it, reinstall the crank, and hoping that works, or, ust swapping in another engine.
So you tried to re-tap the hole?
basically the crank needs a new thread put in it if i have a new thread put in would it be safe to use a different bolt
i am gonna take it to have it re-tap in the morning so will no if i can have it done
I can't read...
if worst comes to worst just get yourself a new bottom end. this happened to my sisters car...except the bolt snapped!
it took me forever to get it out! it was never the same agian.
95 accord/87 ACCORD
I dont know if they make helicoils that big or not but that might work.
Discussion Starter #16
if i cant fix the problem then best bet would be to change the bottom end on it. it is a jdm eg4 d15b vtec that i have so would a d16z6 bottom end be ok to use.
What do you mean it was never the same again? my f22 i got has bolt snapped off into crANk also..i was just gonna drop her by my machine shop...
honda/firebird form.
replace the bottom end my ass.. its called helicoil. works wonders. and you keep the same sized bolt
Discussion Starter #19
lol. anyone no what size helicoil i need so i can get it
thanks
1 - 20 of 35 Posts
