1 - 20 of 23 Posts
Ok so some of you know im doing a vitara build, Basicly The y8 block i have crankshaft is bad, the journals on cylinder 3 cannot even be machined, I have acess to a free d16a6 crank in good shape. Can i use this crank for my build ??? will the crank pullely and all the bearings (rods, Mains) work. Thanks for your help
Dang no one knows about d crankshafts ???
Bearings are all the same, but the oil pump is differant.
racist-bigot-sexist-homophob
Just be sure to measure your clearances. Can you get the girdle from the A6 crank?
yea i could get the girdle too, what would i do about the oil pump
HHHHHEEEEEEEEELLLLLLLLPPPPPPPP a brother out
so ummm what exactly are you telling me??If i get the crank and the girtle will it fit
FAMILY MEMBER #316
might b easier to just find a new block
sometimes people just give em away
will i need a6 oil pan
I've always been under the impression that you should always keep the block and girdle a match pair because they were machined together, and that the crank is "interchangeable"
Well im not going to lie i dont know what allign bore is, but i am getting the block bored and the guy said he wanted the girdle which i do have with pickup as well. I just got the blockguard tig welded in and i am getting the block decked and bored at the same time. Any thoughts on the oil pan ??
We know you dont know Sh*t... You prove that everyday.... GTFO
you can use a y8 oil pump and pick up and the y8 oil pan and the y8 griddle has bigger oil holes in itand lighter and it can be done because im using it in my car right now. I have a y8 head a6 block , a6 crank y8 griddle and y8 oil pump with a y8 oil pan
1 - 20 of 23 Posts
