1 - 6 of 6 Posts
To anyone that may help. I got this crankshaft that has a snout of .845in from a honda motor d16. that i have know idea which block it came out of, right now its in a d16z6 block that my pulleys do not fit anymore for the crank. does anyone know what block it came out of and what year it came out of? also what modle civic si, dx, ex, etc... i would hate to change the crankshaft when all i need to do is change the pullies.
Thanks Rob
crankshaft snout
yeah the d16z6 is a .944in snout the one i just pulled out of the block. so the machine shop got me this crankshaft that the snout is smaller a .845in so im trying to figure out what honda block it came from and year to help me out, to pick the correct timeing belt pulley and drive belt pully, so i can finish putting it back together!
Thanks Rob
Good luck!!!!!!
The crank pullies for the small snout crank only have three rim for alternator belt, Z6 is 4 rib.
I believe the offset is slight off as well.
88 Civic Hatch
where are you located...
1 - 6 of 6 Posts
