1 - 10 of 10 Posts
So I dropped a crankshaft off at the machine shop. (It took me a month to find the crankshaft) the machine shop said everything is perfect besides the crankshaft ends. They said the ends are worn and may leak in the future. What do you guys think, is there anything I could put on the seals or anything to make this work????
Discussion Starter · #5 ·
Appreciate the help man. I'm going to pick one up at O'Reilly and bring it to machine shop and see what they say.
I have never seen that part before. Thank you for posting the link. I may have some cranks that will need that laying around.
Discussion Starter · #7 ·
I just got the crank back from the machine shop and the crank wear is on the oil pump side not the rear seal side so that changes things. The kit is for the rear side so now I'm not sure lol
Discussion Starter · #9 ·
That's what I'm thinking. They do things perfect which I respect. They didn't even want to micro polish it without me looking at the wear so save me the money if I decided I didn't want to use that crank. I'll send pics once I get off work, like I said everything else about it is in perfect order.
Its fine just put a new seal on there and live life.
You can offset the seal slightly, if you really really want to. But it will be fine.
They are basically trained that when you "rebuild" something for a customer, its for a 200,000 mile service life, and if something is a little worn, its obviously not going to make that target. In reality, you will probably put under 50,000 miles on this thing, especially if you are building it for boost. And when someone builds a modified, high performance engine, things like small weeps from seals caused by high crank case pressure is an obvious side effect.
Build it, drive it, enjoy. It wont be worth the hassle or cost to do anything about it. Give it a quick polish with some emery and put er together with some lube and move on. It will probably never leak.
1 - 10 of 10 Posts
