1 - 14 of 14 Posts
sooo i was looking around for bisi parts and came across this term crankshaft offset grinding, did a lil research and what not... What do you all know about this? I kind of dont understand how that works...
The Great Weldini
91 civic
Reactions: TheMadScientist
D-series Janitor
Front Engine Dragste
offset grinding is putting the crank on a lathe and reducing the rod journal by grinding it on a new center.
Draw a circle then draw a smaller circle inside the first one with a part of it barely touching the outside circle.
Its a basic concept but you have to use a smaller rod end obviously.
yeah i understand 100% now. seems pretty cool. but how does it work for destroking? i dont get that part yet. haha
works for stroking and de-stroking
Alot of people do this to f22 cranks to utilize gsr rod bearings
You can also increase the stroke for a lower revving torque monster
Or de-stroke it to better your r/s ratio to more safely rev your f22 to use better camshaft profiles
Same can be said about offset grinding a d16 crank to utilize d15 rods and +/- stroke
Hope this helps, and sorry I didnt give more info on bisi's forums was in a hurry. That was me who posted that for you lol
Reactions: remoer
weld up the journals, the machine them down as needed.
How do you turn a D16 crank with a 90mm stroke in a D15 crank with 80mm stroke????
Offset grinding, like Lopez did for Bisi's D15 that went 10.77 in the 1/4.
The Great Weldini
91 civic
you know bones you amaze me at times with what's rattles up there bettwen those things you call ears...
hum, got me thinking now.
haha naw that wasnt me on those forums, i saw that question though while i was looking for info for my build. and yeah i understand it all now, shits pretty cool..now to do some thinking.
true. it was something i was looking into also. for the use in a f block tho, i was considering the h22 crank vs grinding on the crank. but again, its for a street application. i have always shy'ed away from grinding on a honda crank for the street.
The great archiver I am. In my age I might miss some short term memory loss, but the old links stick around.
41 going on 62, please pay attention, this class my not repeat.
1 - 14 of 14 Posts
