1 - 7 of 7 Posts
what crank shafts for the d series are interchangeable like d15 to d16 z6 to y8 to a6 and what not, i need a new crank for my z6 (spun a bearing and did a good job on the crank)
If you go with different cranks, make sure you either:
a) use an oil pump from the same type block as the crank you'll be using
or
b) verify the oil pressure/volume on the oil pump of the block you're putting the crank into is the same as the oil pump/block the crank came out of.
For example - The oil pump from the Z6 pushes oil at a higher volume than the oil pump from the Y8 and if you're using the Y8 pump with the Z6 crank you'll have oiling issues because the oil galleys in the cranks are different.
1 - 7 of 7 Posts
