1 - 7 of 7 Posts
Ok I got a d16a6 long.block and it.was missing the pulley so I went in stock pile and.none.fit all of them are to big.for the crank shaft snout I have a different a6 long.block and they all fit.on it...
I googled it and no answer and no.luck on here yet.
Is this something.that got covered and if so how do I got about.gettin one ?
Meat Popsicle
91 CRX Si
man I don't.know why you are structuring.your sentences.like.this. it makes it difficult to under.stand what you.re trying.to get across.
that.s.weird that the crank.pulley does not fit.correctly it should slide.right.on since all the d16 crank.shaft pulleys should.be.interchangeable.
yesi found that out i guess i need a 22mm pulley ahh where the f**k will i find one of theses
1 - 7 of 7 Posts
