put the engine on a stand, and brace the crankshaft on the transmission side with a wrench (not the crank itself, but the drive plate or flywheel)Leo7677 said:Anyone have tips on removing the crank pulley with the engine out of the car? I know the bolt`s torqued down pretty tight...anyone else have trouble?
thanks
To get it off use some liquid wrench and tap the bolt a couple times with a soft mallet that should loosen it up a little.RufusG4 said:If a good 1/2 impact can't get it off, then you can bet that corrosion is the culprit (or bad threads), not the torque of the bolt.
