1 - 14 of 14 Posts
ok first off i have an 88 si motor with the 22mm crank snout . now ive lost the crank pulley and im trying to buy just a oem replacement and my dealership is telling me the whole 22mm crank doesnt exsist..... i even tryed majestic honda online and they told me the same thing. they sent me one pulley that fit the crank but it was a dx pulley. then they send me the si crank pulley that has the 24mm hole. but they siad there no such thing as a different size crank snout:evil: . so if anyone has a way of finding out part numbers or knows of a 22mm crank pulley . id like to get a part number to take to the dealership but if not if some one has one ill pay decent money for it.
91 CRX Si
Why couldnt you use the Dx pulley they sent you? Just curious.
i just wanted to keep the original pulley on the motor cause of all the myths of the light crank pulleys but it looks like im ordering one anyway.
I
95 Civic coupe
from my knowledge, the 22mm snout was a carryover from the 86-87 EW motors. Might wanna see if a EW pulley will fit. www.redpepperracing.com might be of help. Just mention "Bone" sent you...........
DX pulley on a EX motor, 10k miles your mains bearings are GONE.
so you would never change the pulley? I wanna install the d13b2 pulley(wihout powersteering) in my d16a6 block, is it an good idea?
transzex said:
why? not gonna do other than clean up the engine a little.
is it not good to have an lighter pulley?
8-9 oz of the pulley, near crank centerline, or 6 lbs off the flywheel 5" off the crank centerline.............
1 - 14 of 14 Posts
