1 - 2 of 2 Posts
1988 Honda CRX Si
I'm going to be ordering new bearings for my build in 2 weeks so I've disassembled my spare block and cant tell what colors were used for bearings.
On the block it has the following <-Pulley| B B B C B |Flywheel->
On the crank it has the following <-Pulley| 2 2 3 2 3 |Flywheel->
Would the colors be the following <-Pulley| Yellow Yellow Green Green Green |Flywheel->
I know i may need different sizes then what block/crank may say now since it has some mileage on it. But seeing as to how half are Yellow and half are Green (if im reading this correctly) i was going to get 1 set of green and 1 set of yellow to plastiguage and determine from there if i need a different size or not.
Soo...am i on the right track so far??
Thanks in advanced,
Mondo
1 - 2 of 2 Posts
