1 - 2 of 2 Posts
I
Anyone had any experience with this cam? Im picking one up from a friend in a trade and im basically getting it free so might as well run it. Itll be going in a d16a6 with a built bottom end boosting around 14-15 psi.
O
if you have a buil bottom end, all you need to do is toss in a set of stainless steel valves and petter springs and you can run higher boosting up to 20psi on pump with the right tunning and setup.
As for THAt cam, i don;t think a lot will have expirence with it yet. it's their new cam, and honestly, I have a hard time trusting anythign that is in stages for a turbo app. also, if it is anythign like their NA setup. the Stage3 will not work well for the streets. you might consider the lower stages isntead.
1 - 2 of 2 Posts
