1 - 9 of 9 Posts
So I just got a 1998 ex couple for free. The bad thing is it had a bad head gasket or so I thought. I pulled the engine and found one of the coolant jackets is cracked on the block. I've done 20 or so head jobs on civic d series and this is the second time I've seen this on a d16 last time it was a y7 and I had a spare short block so it was no problem. The problem now is finding a y8 block. My question is will a non vtec block y7 block work with a y8 head? If so will it affect it in anyway? Also had anybody has any luck getting theirs welded at a machine shop? I don't want to replace with a used block and then 50k later have the same problem so is this common?
how much work have you put into searching for an answer? I can almost bet you that it has been covered close to 10k times, most of those on this site alone
Reactions: robgoof
So there is a thread about d series engines cracking at the water jacket in engine block or welding an aluminum dseries? Funny because I dint find any googled it but found none. I found plenty on people swapping blocks between series of engines for builds but none for a stock or near stock application. Or are you just that guy that likes to be first to reply to a forum saying you should search? Because maybe if you searched yourself you would find that most threads that have been answered have all been answered by some smart guy saying search. Forget the block interchange if you have to. My main concern is success welding this block or reoccurring failures of cracking on stock engines. Funny I can almost bet there is 10k guys just filling up the google pages trying to act smart like you.
1991 Civic SI
OK so you've done 20 head gasket jobs and seen 2 cracked blocks? I think you answered your own question about how common it is. Next yes y7 block will work, literally probably has been covered 10k times. Welding, why would you when blocks are a dime a dozen and cost probably less.
Asshole
His response was in line with your questions not your side story of how it happened. So if you want to forget about whether or not it works and what the differences are if it does then the answer is these blocks are a dime a dozen and not worth welding and causing more damage.
Find a y8 and hope it works or do the research and stop wasting time.
The reason for wanting to weld is to fix a weak spot on a potentially reoccurring problem on these engines. Nowhere else have I seen somebody have crack on that spot when I looked it up online which makes me believe it may be a fluke not a common problem. I ask because in most engine community forums there's engine builders and was hoping somebody had fixed a crack with a weld and how long it later. I don't want to get another block with 100k miles and hope it doesn't crack also. And how would welding cause more damage?
the cracks form only after someone is overheating the fuck out of it.
dont bother repairing.
when Slo-EG8 told you to search, you should make an additional effort
if you do the BASICS and look at a honda partnumber, you will find the d16y7 and d16y8 blocks have the same part number in some of the years, indicating yes, it is swappable.
dude, research starts with finding a method. My personal method is looking up part numbers, both OEM and 3rd party.
It is how I can verify if something is truly interchangeable.
I get satisfaction from not having to open a bunch of threads, even when Im working on cars nearly everyday and come across obstacles pretty regularily
the hardest part is finding a method for yourself. once found, its super duper easy and stress free.
Reactions: slo_eg8
1 - 9 of 9 Posts
