1 - 4 of 4 Posts
do the countershaft bearings have any play?
the two bearings move up and down the shaft a little bit....
F
Assuming you mean the two retained by the nut, then yes, they outer race has some movement. the inner race should not.
depending on what tranny your working on, the inner bearing race can move 1/8-3/16",
Usually EX/Si roler bearing have the slop.
its a y8 tranny, but i prolly should replace the top most bearing since it is quite noisy
1 - 4 of 4 Posts
