1 - 4 of 4 Posts
civic lol
will this resistor box work on the installation of dsm 450cc injectors?d16z6 head d16a6 block everything else is d15b7
well are the injectors high impedence or low impedence? because if they are low then they need it other wise they don't require the resistor boxs.
You should match the head with the correct dizzy, so if you are using a z6 head use a z6 dizzy.
1 - 4 of 4 Posts
