Well my lower radiator hose is only a little warm/barely when the car is fully warm. The upper radiator hose is hot like normal. So is this normal or is the thermostat bad? Or maybe something else. The engine doesnt overheat on me as far as the guage reads plus nothing else is wrong. So give me some feedback.Thanks.
8
if the bottom hose is hot also, then your radiator is clogged, the bottom hose should be cool, and the top hose hot....
^^^ yes, the bottom hose feeds coolant into the engine (i think) after it's been cooled by the radiator so it shouldn't be hot or else your radiator wouldn't be doing it's job properly.
Shackle me NOT!!!
1995 Honda Ballade
when last did you flush your radiator? Have it checked if you're in doubt. You're radiator could be damaged.
