1 - 7 of 7 Posts
crx
I was just wondering if there is any specific reason why post 91 d engines have coolant fan temp switch on the thermostat housing before the thermostst instead of on the back of the block ?? any advantages??
Cause the fan only needs to come on when the coolant exiting the radiator is too hot.
Reactions: eddcartes
crx
so im guessing that prolongs the life of the radiator fan motor.
i think ill try that in my crx. seems like my fan is always on ......
\/Your Mom Was Here\/
Vibe GT
I know you are turbo now, what radiator are you running and what t-stat. I always go with OEM on tstat no matter what.
crx
im running a stock crx full size radiator with 95 integra condensor fan that was modified to fit. im running a parts store stat at the moment. ill be getting a honda stat come pay day...
crx
also thinking of putting an insulated shield on the turbo side of the radiator. im sure that side of the radiator is obsorbing heat drom the turbo.
1 - 7 of 7 Posts
